Hi all,
I just finished running a small 3 sht job for some miscl. parts and a cabinet.
First sheet had 8 disks 5" in diameter. Sheet also had a counter top that needed a 2" diameter hole and a rectangular hole with a 1/16" rabbet on the outside edge for a wiring grommet and ventilation grill respectively.
Onion skin on the 5" diameter disks were not cut thru. Left all the disks with onion skin. Disks were also getting cut where there was a momentary pause at 4 points equally spaced around the circumference. 12,3,6,9 o-clock. Is this normal? Had some lomg parts with semicircle ends and the machine did the same pauses at the beginning and end of the circumference's.
Grommet hole was cut out by plunging the bit (.25" MC) into the center and moving out to the circumference and going all the way around. Did this for both passes so it seemed o.k. Didn't leave an onion skin, though. Just cut it out with two passes at the max depth of cut (.375").
Finally the vent grill hole with recess for the vent grill's flange.
Machine cut out the hole in two passes just like the grommet hole. It then made a series of tool paths to hog out the meat. Exciting few seconds trying to get the meat that was now freed from the previous tool paths, away from the bit that was knocking it around inside the hole.
Lastly, on the second sheet that was run, we had straight forward cabinet parts. A left and right side with hinge plate holes, some stretchers and a display panel. Everything was going fine and the onion skins were all cut from all the parts untill the display panel. It was the last part and the bit was just getting into the cut when the machine stopped functioning. I hit the space bar and nothing happened. Bit screaming away in the hole and a big angry STOP in the tool location panel. Finally just killed power to the machine and did a hard reboot on the computer. Started everything up again and pulled the spindle up and out of the hole. Toasted.
Same settings as I was using from an earlier run. Needed to get these two sheets milled to complete the job. First ten sheets had similiar odd shaped parts but went off without a hitch (well...more like different hitch's).
Any one experiencing this kind of erratic machining?
Tim
