Results 1 to 6 of 6
Thread: Imprting PDFs`
    Mar 2009
    Parts and Templates, San Carlos CA
    Default Imprting PDFs`
    Does anyone know why I would get a contains only bit map info error message when I try to import a pdf?
    David
    Sep 2007
    Vectric Ltd., Alcester
    Hello David,
    I am afraid that you can only import PDF files that contain vectors into
    Aspire.
    If you are seeing this message, the PDF file that you are trying to import,
    contains bitmaps.
    I hope that this helps.
    Cheers,
    Mark.
    Mar 2009
    My thought or problem is how does it get saved as vector vrs bitmaps>?
    Mar 2008
    Radford VA
    The standard free Adobe for pdf formats will not save anything as a vector. I am not sure, but you would probably have to purchase one of the professional versions to get this feature.
    I have used www.zamzar.com to convert pdf files into bitmap files a few times. The website has worked well for me. I then take the bitmap and trace it in Aspire or Vcarve Pro.
    cnc routing, portland or
    you can import ext pdf's without a problem. say convert a word text doc into pdf and it can be imported directly.
    Sep 2009
    Surrey, UK
    A lot depends on the starting format. If you've got a bitmap displayed in a program and you use one of the excellent free PDF printer such as CutePDF or BullZip PDF then you'll have a PDF that contains a bitmap.
    However if you print a vector image from a program that supports vectors then you get a PDF with a vector picture in it.
    Printing web pages will get you the text as vectors and the borders for divisions and tables as vectors as well.
