Ususally I am able to figure things out on my own but when I am working with material that is over $400 per sheet for SF3, I thought I would ask before I just start cutting. I am using an 1/8" Taper Ball Nose and 1/4" end mill - I know you can run at faster feed rate but do I need special cutters and what is my maximum depth per pass with the 1/4" end mill?
My plan is to mount it to my machine with a few screws and double sided tape along with blocking it in on 4 sides - are there any better suggestions since I do not have a vacuum system?
Thanks for any help you may be able to give me.
Gary
