You guys may remember the Plybo Boxes, see Show and Tell. Those have done very well and I have a repeat customer. I'm also making risers for them that boost the box height by 4" or 8". If you have a school nearby (especially a private school) it's not a bad gig. Remember http://www.talkshopbot.com/forum/mes...tml?1211823722
They have asked me for a Medicine Ball Rack. So far I've not hit on any ingeneous ideas. If someone has some ideas and would be willing to share them I'll make the final design public domain if it is successful.
They want something that will fit nicely into a corner and hold 6 to 8 balls. It should be "light" in appearance i.e. not a full cabinet system but something with minimal appearance. It should not have "eye pokers" on it, you'll understand when you see some of the links below. It can be secured to the wall.
The balls range from about 13" to 15" in diameter (I think 14" is an official size) and from 4 to 15 lbs.
Equiped with eye pokers or not corner friendly.
http://www.lifestylesport.com/medicine_ball_racks.htm
Again, eye pokers and not corner friendly
http://www.performbetter.com/SearchR...tegoryID_E_378
Don't spend too much effort, I'm just fishing for ideas I can sketch and present. In the end they'll probably purchase 4 of these and the budget is in the $100 to $200 range. That means simple is the key.
They are trying to avoid the "eye pokers" in the design since these are close to the exercise floor.
/RB
