Hi,
For the past 6-years i have been using Fixed speed chinese Router (25000RPM) for doing various wood related projects... I got this Router 4-year back for the amount of 35US dollar... This Router worked very well so far with following issues:
1- Frequent change of Bearings
2- High Noise
3- Can't machine plastic/acrylic/Aluminum at low RPM
To replace the above fixed speed router i have purchased another variable speed router (min speed: 10000RPM, Maximum Speed: 25000RPM), but due to heavy weight and slight modifications in Z-axis plate i never tried to install it...
Recently i have seen a thread on Super-PID speed controller at CNCZone and received one from RomanLini to test out on my DIY CNC machine...
Here is How it works:
"The Super-PID has an accurate LCD tacho with 48 bar power bargraph on the lower half of the LCD. This feature shows the percentage of power applied to the router at all times. The Super-PID can operate a fixed speed router within 5000~30000 RPM range.If it starts cutting, the power bargraph will rise to maybe 20-30% depending on the depth of cut and this is shown on the bargraph even though the speed stays at 5000 RPM or very close. The speed is controlled through Potentiometer"
Attached is one of the Picture of CarveOne Super-PID controller he recently commissioned.. You can see the LCD with speed and power bargraph...
The quality of the PCB and all accessories i got with it was awesome... Now, to install on my machine i started this thread so that if anybody interested for this low-cost speed controller can get help to see lot of pictures i will present here in future...
For now, i have one limitation of mounting the IR sensor as the Router Collete is not extended well to mount it as you can see the router picture...
However, I have a nice idea how to install the sensor in such a way that it will always be dust-proof and foolproof..
Since 8-month i never touched my CNC machine and yesterday i have to clean all the lead screws and ran the machine and i was astonished to get all the axes working without any smoke
I also installed XBOX 360 controller and now i can control miscellaneous functions of the machine standing near it...
