Had a simple little cutting job into some door slabs. Had two doors that had identical tool pathing on their fronts. They also had identical (though different from the fronts) tool pathing on the back. There was 4 total tool path files created. Door 1 front, back. Door 2 front back.
Ran the first slab's front and back. Ran the second slab's front.
Ran the back and the PW code had an extra Z move at the end!
Material was 1.375" thick. Safe z was 1.575". Code viewed in editor shows it pulling the z up to the 1.575". There is then a JZ 1.2" line followed by a J2 0,0. END. Why the extra move down to 1.20" before the jog to home?
I would like to know what went wrong to avoid having the same thing happen in the future. Now a little job that was going to make a little money is going to end up costing me.
SB doesn't have any readily understood answer except, perhaps, something was saved wrong or called something else.
SB had me open the file up in PW and re-save it with a different file name. After ward it was viewed in editor and the problem Z move line of code was gone.
O.K. but what caused it in the first place?
Any ideas?
Tim
