Guys...
Here are a few pics of our latest mod to our ATC machine. We have a project coming up that will require machining a number of tenons off the -X end of the table. Since the 96" machine with an ATC configuration has very little extra X travel to spare, we decided to lengthen the X rails.
I knew we needed a minimum of 3" on the left (-X) end and while we were at it we added 4" to the right (+X) end for a total of 7 inches. This was accomplished by adding a 7" piece of X extrusion, hardened rail, and rail mounting block. We added about 13-14" of rack gear to facilitate mounting. Once the rail was extended, we used a pipe clamp to move the X rails 3" in the -X direction.
This of course, mandated total realignment, leveling and shimming of both X rails. Since I was this far in, I moved the ATC tool holder bar back 4" and up 3". I also built a new Zzero fixed plate and mounted it to the table board instead of on the tool bar, which is the OEM mounting location. This would have to be moved later when we install the 12 tool rotary carousel.
Parts were obtained from ShopBot, McMaster, local hardware store and my stock. All machining done in house. This could be advantageous for those wanting to put in an indexer bay or add fixtures that the OEM rail length wont allow.
