Thread: arched casing
    Nov 2010
    Default arched casing
    i just want to make arch clonial casing--can any one help
    Mar 2009
    Eastern Delaware
    If you have access to Aspire it is very straight forward. 2 rail sweep of the molding profile along the "rails" or shape of your arch.
    May 2008
    Geometree Design, Buffalo NY
    I've done several arched moldings using the extruder tool that is included in the shopbot software. Its not very well documented as to how it actually works but if you read thru the help files and try a couple different options you can get a pretty good idea how it works. It will do what you are asking if you set everything up right.
  1. Door and window casing help needed
    Last Post: 02-16-2011, 12:20 AM
  2. Arched top exterior door
    By john_hartman in forum Techniques for Cutting, Drilling, Machining
    Last Post: 12-13-2009, 03:00 PM
  3. Arched window
    By kubotaman in forum ShopBotter Message Board
    Last Post: 09-05-2009, 08:22 AM
  4. Arched door molding
    Last Post: 06-16-2009, 08:49 PM
  5. Arched Panel Templates - Help!
    By robinsoncr@naxs.net in forum Archive 2003
    Last Post: 11-18-2003, 11:21 AM
