Hey Shopbotters,
I just received my new Shopbot Desktop! Woa! I am setting up now.
All I am using this machine for is one type of project: I will be carving detailed, photo-based, low reliefs into acrylic sheets (It's an odd project – the carvings will function as molds that I will make casts from.)
Relief Depth: 1/4 in.
Size: just under 18x24 in.
Bit Size: 1/8 in.
I am a computer graphics person. So the software part is easy for me. It's the mechanical, physical, and material issues that are intimidating.
Please bear with me on such basic questions, as I have zero experience with tools, bits, routers, cnc, etc.
Questions:
1. What's the best way to set up and attach a spoilboard to the t-slot base that the desktop comes with? Do I just bolt a piece of 1/2" MDF to the t-slot? Anything I should watch out for?
2. I don't have a vacuum system, how should I hold down the material? Do I need downward pressure, or do I just have to worry about side to side movement? Can I just screw a few scraps of MDF around the edges of the acrylic sheet to keep it in place? Should I clamp instead?
3. The machine time is going to be crazy – the test I had fabricated took 15 hours to get the detail I needed. I need the detail, but is there another material that I could cut faster?
Thanks so much.
I've already received many great insights from the forum.
Best,
Daniel
