The problem that I am having has happened before using the "S" and "R" keyboard commands.
I often use Aspire V2 to create "peck" holes for cabinet shelves.
I have stopped the peck drilling program using the "S" soft stop command with disasterous results after starting again.
The procedure:
1. To resume, I use the "R" resume command.
2. This is when the problem occurs. The machine tries to move to the correct depth WHILE STILL MOVING IN THE X and Y Position. It should move to it's new position first (ie moving in the X&Y only) before drilling the peck hole. The result is a broken bit and damaged cabinet.
What is going on?
Has this problem happened to others out there? I would like a solution since I often use the "S" stop and "R" resume keyboard commands.
Tom
