Results 1 to 5 of 5
Thread: What is the command SC?
    Feb 2007
    hobby, Asheville NC
    Default What is the command SC?
    I find on my cu butt files from Aspire the command SC followed by 1,1 or 1,0 but I can not find it listed in the command listings.
    Feb 2004
    Rogers, Arkansas
    SC is clear user variables. Are you sure you're not seeing SO,1,1 which is set output 1 to on and SO,1,0 which is set output 1 off. This is normally used to start router or spindle.
    Ken Zey
    Rogers, AR
    www.CedarSlabSigns.com
    www.lookoutmercantile.com
    www.digitalmillwork.com
    6x12 PRS alpha
    Apr 2007
    Marquette, MI
    Ken is partially correct. [S] [L] is clear user variables. You probably have the [S] [O] which does turn a spindle or router on (or off depending on 0 or 1).
    [S] [C] may be a legacy command that set to single step mode. Hasnt been used in a long time
    Gary Campbell
    GCnC Control
    GCnC411(at)gmail(dot)com
    ShopBot Controller Upgrades
    Albert Einstein
    Sep 2009
    Surrey, UK
    If you're looking at the file in the ShopBot editor you might find that what you think is SC is in fact SO.
    The font used in the editor makes a capital O look like a capital C.
    AS Gary says the SO command is used to switch the outputs. SO,1,1 usually turns the spindle on and SO,1,0 turns it off.
    Feb 2007
    hobby, Asheville NC
    Default it is SO
    Thanks all-when I look closer is see the very light part of the O. Thanks all
  1. C3 command changes
    By gc3 in forum Troubleshooting
    Last Post: 12-17-2011, 04:36 PM
  2. MO command
    By Mike Windsor in forum Troubleshooting
    Last Post: 02-13-2011, 04:55 PM
  3. Help with FG command
    By toddho in forum ShopBotter Message Board
    Last Post: 11-07-2010, 08:20 PM
  4. need help with a command
    By knight_toolworks in forum ShopBotter Message Board
    Last Post: 08-18-2010, 07:36 PM
  5. CP command
    By propellers in forum Techniques for Cutting, Drilling, Machining
    Last Post: 05-11-2010, 09:28 PM
