So over my winter vacation (one of the the perks of academia) I started sketching out an idea for custom tool that would require use of the A/B-axis, ideally with a small 12v stepper. Basically I saw some work people have done with a 6-axis arm and knew I could do similar with only a 4-axis machine (because thats what I have access to). I figured it would be something fun to work on so decided to hit the ground running when we started up after the break.
I have a couple questions that I thought I'd post here for some advice. I did go through the indexer installation documents that came with the machine as I figure that would be the best place to look, but they're for an earlier version of the control box and I wasn't able to gleam too much from it.
1. I have a PRSstandard with the latest control box and opened up the cabinet first thing when I got into the shop today. I see there are 4 stepper controllers - are the two X-axis's controlled separately or is the 4th controller available for the A-axis? I'd like to avoid having to buy a new controller as I don't own the machine and don't have too much money to be throwing into this project.
Answered this with some digging through the archive. Since I'll have to buy a stepper controller this project will be need to be put off for a bit. I wonder if ShopBot sponsors projects...
2. What are the properties of the stepper pulses (voltage, etc.). I'm hoping that I would be able to step-down the voltage in-line without degrading the pulses, but would need to know what I'm dealing with before I start developing the circuit for this.
Any help on any of this would be appreciated!
Cheers!
