Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: The machine dont move
    Aug 2010
    cuenca ecuador
    Default The machine dont move
    I star my machine today prsalfa, I have this message:
    the remote stop button connected to imput #4 appears to be ON and need to be checked.
    also the spindle dont work
    I cheked the blue reset button, the 2 stop red button, and still the same
    message anybody please help me.
    Apr 2007
    Marquette, MI
    alberto...
    is the machine in Move/Cut mode?
    Gary Campbell
    GCnC Control
    GCnC411(at)gmail(dot)com
    Servo Controller Upgrades
    Albert Einstein
    Aug 2010
    cuenca ecuador
    Hi gary yes is in move/cut mode
    Feb 2004
    Rogers, Arkansas
    Check that setting VN Switch 4 stop is set to 'NRM Closed' and hasn't somehow changed.
    If you hit the stop button, reset it, then press reset does the relay 'clack'? I've heard of people having trouble with stuck relay once in a while.
    The other possibility is a break in your stop switch wiring. It's a normally closed circuit so any break in the wiring is just like the stop switch being triggered.
    Ken Zey
    Rogers, AR
    www.CedarSlabSigns.com
    www.lookoutmercantile.com
    www.digitalmillwork.com
    6x12 PRS alpha
    Aug 2010
    cuenca ecuador
    Hi Ken
    I checked VN switch 4 is set to "NRM CLOSED"
    The relay "clack" O.K.
    The wiring O.K.
    Dec 2008
    , Richmond Tx
    There were two contactors in mine that both had to (clack). It is possible that only one of them are (clacking)
    You have to look inside with the power on and then hit the blue button. If there are two of them between the incomming power and the Drivers, they both have to pull in when that button it pushed.
    If your e-stops were bad, I don't think you would hear anything when you pushed the blue button.
    Kenneth
    Aug 2010
    cuenca ecuador
    Hi Kenneth
    I don't see the contactors but pushing the blue button I hear 2 (clacks) and the drivers z and x left side goes on (GREEN LIGHT) the other 2 are off, I don't know if works that way
    Dec 2008
    , Richmond Tx
    All of the drivers should have the green lights on.
    Kenneth
    Aug 2010
    cuenca ecuador
    The gay who wiring the machine just tell me he put the 2 black wires to 220 and he turn on the machine make sounds like (popcorn) later he change to 110 do you think this action damage the drives and the main board
    Dec 2008
    , Richmond Tx
    He either blew the fuses in the control box, or burned something up. On mine one fuse goes to all four drives. Check all fuses first.
    The main cable on mine takes 220 volts, but they are not all the same. Some are wired for 3 phase as well.
    You may need to send the control box back to shopbot for repair.
    I think you need a new electrician too.
    Kenneth
  1. Replies: 8
    Last Post: 06-10-2014, 03:49 PM
  2. Replies: 5
    Last Post: 06-07-2009, 07:23 PM
  3. I dont under stand
    By bryan_webb in forum Archives2008
    Last Post: 08-05-2008, 06:28 AM
  4. Machine won't move.
    By gdayers in forum Archives2004
    Last Post: 10-20-2004, 07:01 PM
