I am running partworks 2.5 and for no reason on just some projects the file runs out of code, just stops in mid cut. I can't make it happen and it doesn't matter if I am cutting, carving, pocketing......
Ron
Ron
Ron:
My Bot will pause while more code is loading, does yours eventually pick up again? I’m running my files from a NAS drive (network aware storage) and they aren’t as fast as a local drive. Are your files so long that your drives are going into sleep mode?
Just some thoughts…
Steve
Could use a bit more information...type of ShopBot, SB3 version, post your code maybe.
Ron:
Did you ever solve this mystery?
Steve
Sorry for not getting back sooner to you all but... yes it appears that it was a network issue. Thanks again for all your input!
