Results 1 to 5 of 5
Thread: pulley with teeth, can anybody get me started?
    Apr 1999
    Rock Hill SC
    Thumbs down pulley with teeth, can anybody get me started?
    I am trying to cut a timing pulley with 200 teeth on it. I have drawn one tooth to the correct dimensions on Turbo Cad. I would like to import that as a DXF file into Part Wizard and generate a 200 tooth pulley that I can cut out of plastic.
    How do I do this?
    Tom Lempicke
    Tom,
    It's probably easier or just as easy to do it in TC with the "Radial Copy" or "Radial Fit Copy". You'll need to know the base diameter of the pulley.
    Delray Beach, FL
    Save your drawing to dxf, dwg, eps, or ai. Open your partwizard and setup your job. Then go to file and click on import. You may have to play around with the different file types to get a clean import as it mostly works with older versions of other files.
    An option may be Ryan Pattersons gear program he did a bit ago. A lot of guys also use a program called woodgears. After all, a toothed pulley is just a gear by another name!
    http://www.cabinetpartspro.com/OtherProducts.aspx
    http://www.woodgears.ca/gear/index.html
    Apr 1999
    Rock Hill SC
    Smile
    The gear program is so nifty that I am going to buy it just to play with it.
    Seriously it looks like that will do the trick. thanks for the help
    Oct 2000
    Willis Wharf, VA
    If you're a Sketchup user or just want to learn a little more about gears, there was a good posting yesterday about creating gears in Sketchup on the Capolight Electronics Blog that talks about a lot of the different properties and types of gears.
    http://capolight.wordpress.com/2011/...s-in-sketchup/
    Bill
  1. Grinding Teeth...
    By 9r2a5m70 in forum Assembly & Maintenance
    Last Post: 05-06-2011, 04:52 PM
  2. Just Getting Started
    By jason_remillard in forum Archives2008
    Last Post: 04-04-2008, 10:42 PM
  3. Getting started
    By f0bic in forum Archives2007
    Last Post: 11-09-2007, 11:12 PM
  4. Where to get started with 3d
    By bpfohler in forum Archives2007
    Last Post: 11-06-2007, 09:30 AM
  5. Wailing and Gnashing of Teeth
    By graphicmetals in forum Archives 2003
    Last Post: 06-19-2003, 07:10 AM
