Hi Mike,
I'm afraid we sort of hijacked Rick's thread, and may be guilty of "information overload"... Sorry Rick.
Anyhow, since we've gone this far, why stop now?
So I looked for info on the A6497-9412KTG motors that Rick said he has on his bot. The Oriental Motor site didn't have anything about it online, but a Google search turned up a reference to it on CNC Zone. It was described as "2 Phase, 1 Amp, 4.39 ohm". That is second-hand info, and it conflicts with Mikes info so I'm not sure what to believe. At any rate, it doesn't really matter that much. the Geckos won't complain either way. Just make sure you install the right current-set resistors per the Gecko manual else you risk overheating the motors.
The bottom line as far as I can figure is that that toroid is probably way bigger than needed, which is fine, and the voltage should fall in the mid to high 60s after rectification and filtering, which should also be fine with a comfortable margin. Just put a 5000 to 10000 uF electrolytic cap with a voltage rating of at least 100V across the rectifier output, and the power supply is ready to rock.
Jim
PS. Mike, that first line in your last posing is confusing me a bit. Wouldn't half coil give you half the inductance rather than 1/4 as you stated, or did I misunderstand your meaning?
