Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: V-Carving Question about line thickness
  1. #11
    Feb 2010
    Towson MD
    Gene,
    I bought a set and will start experimenting once I find a place to get some smaller collets for my HSD spindle.
    Thanks!
  2. #12
    Sep 2008
    Quote Originally Posted by archis View Post
    Gene,
    I bought a set and will start experimenting once I find place to get some smaller collets for my HSD spindle.
    Thanks!
    ER what? plenty on E bay
    D/M ?
    Vector Studio 22
  3. #13
    Feb 2010
    Towson MD
    Should have guessed Ebay. D/M??
  4. #14
    Feb 2010
    Towson MD
  5. #15
    Dec 2008
    Diamond Lake, WA
    Jim,
    I use the v-bits from ToolsToday.com. They have a shank that holds carbide blades. These blades can be interchanged so 1 time you are running a 60 deg blade and then you could be running 90 degree blade without changing the bit. You only change the blade.
    The shank assembly is expensive but the blades run about $15.
    They seem to cut a cleaner V for me anyway. I've tried the solid carbide v-bits that are ground to a point and there seems to be more mashing of the wood fibers instead of clean cutting. I've even taken 2 or 3 swipes with a honing stone on each of the 3 ground areas and it still seems to crush more then cut.
    Don
    www.dlwoodworks.com
  6. #16
    Jan 2009
    Veracruz, Mexico
    I use these for fine detail, the Amana has been the most useful so far, a little pricey but well worth it
    http://www.woodworkersworld.net/carv...bit_bits.shtml
    http://routerbitworld.com/Amana-4573...na%2045730.htm
  7. #17
    May 2005
    Fox Bay Industries Inc., Auburn WA
    Archis,
    I found this site on CNC Zone under PCB milling.
    I bought a 30, 45, and 60 degree bits from the site listed below.
    http://www.drewtronics.net/
    I have only played with them a couple of times, in MDF, and they seem to cut pretty nice.
    Good Luck,
    Wayne
  8. #18
    Feb 2010
    Towson MD
    Thanks Everbody for the suggestions. I have a lot of options to explore now.
  9. #19
    Feb 2010
    Towson MD
    I got these to experiment with
    http://cgi.ebay.com/5x-PCB-Engraving...-/350350437482
    For MDF and Cedar what should I use for RPM and feed rate?
  1. Carving Question
    By jwa1156 in forum ShopBot Desktop
    Last Post: 07-23-2014, 07:29 AM
  2. question about dimensioning board thickness
    By NickB in forum ShopBotter Message Board
    Last Post: 05-12-2014, 01:21 PM
  3. 3D carving question.
    By david_gardner in forum ShopBotter Message Board
    Last Post: 03-13-2009, 06:40 PM
  4. Million line question
    By walksonwater in forum Archives2007
    Last Post: 07-12-2007, 07:42 PM
  5. AutoCad LT Line Thickness conversion
    By c_hoose@email.msn.com in forum AutoCad
    Last Post: 06-01-2000, 01:32 AM
