Hi, I'm in the market for a ShopBot and wanted to build drawer boxes. Has anyone tried making decorative drawer box joinery, like Dovetails, Boxjoints, etc.? Thanks, Peter
Peter,
Dovetails and box-joints are structural. I have cut dovetails on The ShopBot.
Ron
I've cut dovetails, box joints, and 'dogbone' joints.
anything you can route with a template or pattern, you can route with at shopbot.
da
Correct me if I am wrong, but you'd have to position the dovetails towards the ceiling in order to cut them, right? This would limit the length of the drawer to the Z clearance under your bit....Right?
-Brady
Not if you fashioned a vice at the end of your x hmmm.
Dale
...or cut a slot through your table.
Slot throught the table and a hole in the floor, IF needed. Otherwise plan a machine that can have a horozional axis router. Then you would be limited by the length of material one could load.
Gentelmen, you are limited ONLY by your imagination.
Ron
I used a vertical vise, it was demo'd at the NJ camp shopbot, 3 years ago. of course if it can't be done, obviously I didn't do it.
But, of course, it obviously can. Here's a picture of my first try at a drawer joint using a 40+" dovetail clamp on my 'Bot:
Morris
