Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Fit Clearance and small shoulder
    Jul 2008
    Default Fit Clearance and small shoulder
    Ok so I am up and running with e cab. Cut out a few boxes from some oak and they turn out ok. So then I switch to some cherry and it was off from the oak by .002. The Dado and Tenon are really tight. Is there a formula at what to set the fit clearance or do I have to just keep track of the difference thicknesses of the plywood? Also there a small shoulder at the end of each Tenon how do I get rid of it.
    Thank for any help.
    Apr 2007
    Marquette, MI
    Frank...
    Looking for a little more info here....
    You say off from Oak by .002. Can you explain further?
    Were the 2 files cut with the same dado %, depth & fit clearance?
    Was the bit changed or the tacle surfaced btween the 2 files?
    Do you zero to the top of the material or the spoilboard?
    The plywood thickness has no effect on the dado/tenon fit. The settings, the accuracy of your Z zero have much more effect on the dado accuracy.
    You may want to re-mic the parts to see if they are the same thickness as the design value.
    What is material thickness?
    What is tenon %
    What is actual thickness of tenon as measured with a digital mic?
    (the tenon thickness should be the mtl thickness * dado%. My guess your actual is thicker.)
    When the outline cut and tenon dado do not line up at the tenon shoulder it is almost always a mechanical issue. Usually the X. Double check pinion to rack clearance and your pinion grub screws.
    GCnC Control
    Servo Controller Upgrades
    Albert Einstein
    Jul 2008
    ok. First I sorry I am running blind dado.
    the .002 is the difference in thicknesses between the too plywoods.
    yes the two file were cut with the same dado% and fit clearance
    the bit was not change and I rezero to the top of the material
    I have to take a pic of the last thing as I don't know how to say it.
    Apr 2007
    Marquette, MI
    Frank...
    I am pretty sure that I know, and have seen your problem. Check the pinions and grub screws. If the X are loose, check the Y also. I will be at the shop in the morning. Call if I can help
    GCnC Control
    Albert Einstein
    Jul 2008
    I hope this work. gary this is the problem I have been having. How do I get rid of this?
    thank
    frank
    Apr 2007
    Marquette, MI
    Frank...
    Only 2 causes for this, as far as I know.
    1) Mechanical (most likely) check pinions and grubs as above. Make sure parts didnt move. (is tenon similar on other end of part?)
    Mic the tenon and see how it compares with your design value
    Did you mic the tenon thickness?
    2) when using different bits for outline & dado, 1 has size listed improperly
    I am sure that 1) wins in your case
    GCnC Control
    Albert Einstein
    Jul 2008
    the part did not move and all the tenon are the exact same. Everthing on the machine is as tight as I cam get it. there no movement of any kind. and all the cut are very precise. all tenon are the exact same all seven. so when I but them together i have a little should at each end. Rasing the center. I am using the same bit for both job. there has to be a setting some where to set the tenon depth into the material.
    Apr 2007
    Marquette, MI
    Frank...
    Have you mic'd the parts that I requested?
    I need the material thickness (design)
    Tenon % (design)
    Measured tenon thickness
    Measured tenon length
    GCnC Control
    Albert Einstein
    Jul 2008
    as soon as I can get back in the shop tommrow I will get what you ask for.
    thank
    Jul 2008
    Ok Gary I think I got what you want to help me.
    e-cab setting
    Dado depth .375
    Depth clearance .025
    Fit clearance .03
    Thickness % 53
    Link setting
    .05 dovetail radius crunch
    100 male dove feed rate
  1. Zero clearance insert
    By Michaelodunk in forum ShopBotter Message Board
    Last Post: 05-11-2015, 06:32 AM
  2. Z clearance
    By ccwerks in forum Techniques for Cutting, Drilling, Machining
    Last Post: 08-04-2014, 05:12 PM
  3. Rapid clearance gap
    By tomahack in forum Archives2008
    Last Post: 10-24-2008, 03:13 PM
  4. How much Z clearance...
    By harryball in forum Archives2008
    Last Post: 10-07-2008, 10:38 AM
  5. 6" Z clearance
    By johnny in forum Archives 2003
    Last Post: 01-13-2003, 07:02 AM
