Has anyone seen a dovetail bit the is around 3/16 diameter at the bottom. It is used to hold a weather strip into a boat hatch. I've look at Magnate, CMT, Centurion, Onsurd, Whiteside.
Tracy Spitulski
KenCraft Co Inc.
PRSa 6096
www.kencraftcompany.com
Hardwood Lumber, Custom Millwork
Dust Collector Fittings
Amana has one 1/4"
http://www.amanatool.com/routerbits/...its-45837.html
Freud has a couple that are 1/4"
http://www.buyfreudtools.com/index.p...tegoryId=58110
If it has to be smaller than that maybe Fred at centurian will make them up for you
Harvey tool is who you want. They have many styles here is the O ring type that will plunge they also have drop hole type and many other styles. They are not cheap though.
http://www.harveytool.com/products/p...vetail+Cutters
WWW.MillerMarineProducts.com
Proto Trak DPM CNC Bed Mill
Brand X Industrial router
Sharp SVL-2416SE-M VMC
Thanks guys. That is what I was looking for.
Tracy Spitulski
KenCraft Co Inc.
PRSa 6096
Another source is Micro 100. I've used many of their cutters both on my Bridgeport and my SBT.
How can I add a dovetail profile to the tool data base in Vectrix Vcarve Pro?
I know that it is not important as far as the actual tool path but the 3D view will not be correct unless the cutter profile is in the tool data base.
You can't. It's not possible to create any tool with an undercut in either VCarve or Aspire.
You have to define it as a standard endmill.
http://support.vectric.com/aspire-qu...-with-undercut
try this site http://www.precisebits.com
www.tgdesigns.net
eking1953@yahoo.com
ST. FRANCIS OF ASSISI
