I’m trying to find a 3D file that is like the attached picture, I’ve looked on the 3D site that I’m aware of. Does anyone know where I can find it?
Thanks for Your Help
Jimmy
Jimmy
I’ve never been fired, but, I have been laid off when they were still hiring.
PRS Standard 48"x96" with PC Router and Aspire 9.008, Cabinet Parts Pro
www.cncsignshop.com
cncsignshop@nc.rr.com
919-802-7477
Jimmy,
I assume you are looking for the center design?
If you are using Aspire, there is an included model that comes very close. If you need it closer, you can modify the design in Aspire.
Tim
Tim,
Thanks for your help. I do use Aspire 3 but I can't find that File. I'm sure it's there, what would it be under?
Jimmy
www.cncsignshop.com
919-802-7477
Jimmy,
Unless you copied the included 3D clipart to your hard drive it would be on the Aspire DVD. If you upgraded from Aspire V2.X to V3 it would be on your original DVD you received when you purchased Aspire the first time.
The name of the file is what's listed under the picture I posted.
Let me know if you are still having trouble and I will pull out my original disk.
In case you don't know this, you got 50 VectorArt3D models, each in the three styles, free when you purchased Aspire. If you find them on the DVD you may want to copy them to your hard drive for quick access.
Tim
Thanks Tim,
I found it.
I'm not sure that will work though
www.cncsignshop.com
919-802-7477
