Results 1 to 7 of 7
Thread: SketchUp Topo
    Mar 2011
    Louisiana
    Default SketchUp Topo
    Good day to everyone,
    We've recently finished assembling our PRSalpha and are testing out file types to cut. I have a sketchup model with a draped topo, and I was wondering if someone could point me in the right direction as far as cutting out the topo with my tool. One option that comes to mind is exporting the skp file as a 3ds into Rhino? I'm not sure if that would translate very well. Or Is there an easier way to cut a topo model from SketchUp?
    -P
    Sep 2009
    Surrey, UK
    What software do you have available? Partworks, Partworks 3D, Aspire etc?
    I export from Sketchup Pro in obj format and import that into Aspire. PartWorks 3D supports that file format too.
    Mar 2011
    Louisiana
    Thanks for the reply,
    PartWorks and PartWorks 3d. I was hoping to get by with that for now. So have you or know someone that has exported SketchUp topo successfully to PartWorks3D?
    Sep 2009
    Surrey, UK
    I don't see why it shouldn't work. Once the drape has been created it's not seen as any different to any other model by Sketchup as far as the export process is concerned.
    Before I switched to Aspire I did quite a few Sketchup models in PartWorks 3D without problems.
    Mar 2011
    Louisiana
    Excellent,
    I'll give it a go, if I run into any issues ill let you know. Is there a reason you switched to importing your sketchup files into Aspire? Like I said, i'm trying to stick with PartWorks and PW3D for now, but if Aspire is worth I might have to invest.
    -P
    Sep 2009
    Surrey, UK
    The biggest advantage of Aspire over PartWorks 3D when working on imported models is the ability to clean up and further process the model before cutting.
    Also I find it much easier to model reliefs in Aspire than I do in Sketchup. I tend to use Sketchup for more traditional furniture designs these days.
    Mar 2011
    Louisiana
    adrianm,
    Another quick question, when you exported from sketchup did you use .3ds or .obj? Also, what export settings, if any, did you change in sketchup to create the best output file for partworks 3d?
    -P
  1. Topo cut
    By scottp55 in forum ShopBotter Message Board
    Last Post: 09-21-2016, 08:34 AM
  2. 3D topo Katahdin Cocobolo
    Last Post: 09-02-2016, 06:34 AM
  3. Cutting test topo
    By cnc_fabricator11 in forum Techniques for Cutting, Drilling, Machining
    Last Post: 04-13-2011, 10:46 AM
  4. 3D topo from contour lines
    By tim_m in forum Archives2008
    Last Post: 03-21-2008, 02:13 PM
  5. Carving Topo models
    By dubliner in forum Archives2007
    Last Post: 12-20-2007, 12:22 PM
