Currently have a job loaded in the link that requires a rafix hole pattern.
Pocket operation seen as a drill operation when it's a st. line and arc has been selected.
Rafix drill bit is the largest and first operation in the tool file. Next operation is drilling 5mm holes, then the MC. Compression bit.
When I load the job file and 1st sheet comes up it has Rafix holes in it.
First tool called up is the 5mm bit. Skips over the rafixs bit. Don't know what else to check. Tooling hasn't changed from last job I ran. It also had rafix holes. Called up rafix bit as the first operation.
Any suggestions?
