This is continued from here:
http://www.talkshopbot.com/forum/sho...d=1#post108544
Sound great Gerry. Maybe we can negotiate some improved pricing too with a combined purchase! I emailed an enquiry for complete kit price and also asked if they had any shop drawings to adapt from.
Torchmate uses one on their lasers which is an open design not too suited for flying woodchips. You can't see much in the picture (attached) but it gives an idea.
I just did a little calc for design purposes based on precision machining of the mounting plate and no "idler arm" using Motiontek parts with a 20 tooth small pulley and 60 tooth large pully to utilize their pre made up 600mm 120 tooth belt the center distance of the two shafts comes out to 196.53mm. This gives a belt length of 600mm which is their larges stock length.
That's like 7" and seems large to me. Mike's list called for a 150 tooth belt and I went with what they had that was closest to that. That's obviously not a critical number and I'm not sure what the issue would be if a smaller belt was used to bring the center distance down. If their 360mm belt were used then the center spread is 76.415. Thats only about 10mm between pulleys and could be too close for comfort but if there are no other physical constraints then the result is about as small as a gear box you could go. For the 400mm belt the spread is 96.455 and that yields 30.6 in between pulleys
