Hi All,
Here's my latest problem. I sure hope someone can help me with this one.
I've got a PRS Alpha with a 4HP HSD Spindle with the Spindle Controller.
When I start it up I can only start the spindle once. So if I do a warm up routine well that's it. The spindle won't start anymore after the first time.
If I've got a cut I really need to make I'll forego the warm up routine and just make the cut. If I have to make another cut or change the bit well now I've got a problem because I have to power off the ShopBot and restart it before I can get the Spindle to start again. Oh yeah. There's no error message or any indication that there is anything wrong except the fact that the spindle will not start. No way. No how.
It used to happen only once in a while but it got worse and worse until that is what happens every time. My machine is fully grounded as per Gary Campbell and I've eliminated any source of electrical interference that I can think of. I won't even keep my cell phone near it now. The weird thing is that this has kind of crept up over time. I was running 3.6.32 and thought that might be the problem so I went back to 3.6.18. That work for a while and I thought I had fixed the problem. Then it slowly started to do it again until it got so bad that I went back to 3.6.32 again. That helped for a while too but again; it started to get worse and worse until I was back to the same old.
I contacted ShopBot support a week or so ago and was told that others who have had this problem fixed it by plugging the USB for the Spindle Control Card directly into the computer instead of a hub. That worked for a little while but then not.
It's a real hair puller because it's so inconsistant. The thing that fixed it last time won't work the next time.
To tell you the truth I'm sick and tired of spending so much more time working on my Bot instead of working with it.
I'll give Support a call tomorrow to see if they have any ideas. If any of you have any ideas on how to fix this problem I'd sure appreciate the help.
