I just got all the parts from ShopBot to turn my 48x48 into a 96x48. All assembly is done as of this morning...
My question is what all parameters do I need to change in SB3?
Thank You
Thank You
PRS Standard 96x48 2.2 HSD
Plastics is my thing....
In Tools is the Shopbot setup program but it won't let you change your type of SB andf table size. You will have to do that from the my_variables.sbc file on C drive in the SB Parts folder. I will repeat SB's warning: Be very careful here.
Otherwise you can un-install and re-install and run new set-up.
You could just do a UR (Utilities Reset), follow the prompts and then choose the machine size you now have.
That's a better way Scott: I didn't know that command.
