Results 1 to 9 of 9
Thread: Lead In, Lead Out
    Mar 2011
    York Pa
    Default Lead In, Lead Out
    I am cutting counter supports with Plam on both sides. What I'm looking for is a way to lead in away from the piece, cut the piece, and lead out when finished cutting the profile so it doesn't chip the Plam.And also, is there a way to plunge in at the same location of each piece instead of letting the software choose. I am using Part Wizard.
    Todd
    Select the vector and press the 'N' key. This will get you out of selection mode & into Node Editing mode. Hover your mouse where you want the tool to enter the material and press the 'P' key. This can also be done by just selecting the vector outline & hover your mouse where you want the start to be and press the 'P' key - it doesn't work 100% of the time, so you might have to go into Node Editing mode.
    Under the Profile toolpath, there is an option to both lead in & lead out. You have hit the check box to expand that section of the toolpath fill-in sheet to see it. It's been there since v1.02
    Delray Beach, FL
    Todd:
    I do this all the time with no issue by using a decent mortising bit. You can also make sure your start point is at the top of the support in back where it can't be seen once you are done installing just in case. You want to plunge for plastic speeds so you don't pop through the surface.
    Mar 2011
    York Pa
    Brady and Dave, I've done the start point, did my toolpath, zoomed in to check the toolpath, And it shows that it is leading in, in the middle of the radius. That's not what I want, I need it to lead in at the top corner where it won't be seen. I have never had any success when I've done it beforeand I thought there was something I was missing and that's why I posted the question. My start point is green like it should be but it won't start there. Any other suggestions? Getting a little fustrated.
    Todd
    Oct 2000
    Atlanta GA
    Part Wizard or PartWorks? Brady's steps sounded like they are for PartWorks. If that is the case than you need to select "Use vector start points" to force it to start at the Start Point you created.
    David Buchsbaum
    Beacon Custom Woodwork, Inc.
    dba Atlanta Closet & Storage Solutions
    404-309-9146
    david@atlantacloset.com
    atlantacloset.com
    beaconcustomwoodwork.com
    I was talking about PartWizard...
    You can choose a straight OR circular lead in by selecting either one. It's pretty simple...experiment on scrap 1st.
    Delray Beach, FL
    You can insert a start point wherever you want on your object. Select the vector, go into node edit, hover over the spot where you want to put a start point, right-click, and select "insert start point".
    By the way, have you made sure that the different lines and curves you created to make your object are fully joined? (Select all vectors, right click, select join)
    Mar 2011
    York Pa
    I'm using Part Wizard 1.020. I can hover over other points and make them a start point but, the corner where I really want to start, won't let me. I guess I'll figure something out. Thanks for your help
    Zip up the .art file and post it. OR post a screen shot. A pic is worth a thousand words...
    Help us help you.
  1. lead in and out
    By TadS in forum ShopBot Control Software v3
    Last Post: 11-08-2013, 07:31 PM
  2. lead in and out
    By TadS in forum VCarvePro and PhotoVCarve
    Last Post: 11-08-2013, 05:30 AM
  3. Help with Lead Ins
    By pyrodenis in forum ShopBotter Message Board
    Last Post: 11-24-2010, 08:42 AM
  4. Lead in/ out
    By GlenP in forum VCarvePro and PhotoVCarve
    Last Post: 10-28-2007, 07:05 PM
  5. Lead ins and
    By andrewm in forum Archives2005
    Last Post: 02-02-2005, 09:43 AM
