Results 1 to 10 of 11
Thread: Scanning parts into software?
    Apr 2011
    Cincinnati
    Default Scanning parts into software?
    I just placed my long awaited order yesterday for a new BT48 - now that it's really happening I'm nervous about putting it to work
    My question is: I have a large number of paper patterns that I have been using with my bandsaw and scrollsaw. I take a "master pattern", copy it, glue it to the part to be cut, and then cut the part out. I would like to produce these parts on my shopbot but am uncertain of how to import the paper plans that I have into software that the shopbot can use. Can I scan my paper plans into the software and then add pathing?
    Apr 2011
    Colorado Springs
    PartWorks (that comes with the machine) has the ability to trace a bitmap to a vector. It may need a little cleanup but seems to work very good. I am just coming from where you are. I have scads of patterns and they all need conversion eventually. Over the years I have tried tracing in lots of software. I have never found anything as good as the PartWorks or any ov the Vectric applications.
    If you need help with that, look here;
    http://www.vectric.org/video/aspire3...velocette.html
    I think this is an excellent example for you and is the same as PartWorks.
    ShopBot should be emailing you a link so you can download the software and practice before the machine arrives. I have about another week before I get mine.
    Brain,
    If you have a flatbed scanner or a printer with a scanner, you can scan and save them as a .jpg and then import that into PW for tracing with the trace tool or manually do a trace and node edit it to design the part for toolpathing. For line art, I find it easier to just do a manual trace and node edit to the desired shape than using the trace tool as it usually takes just as much clean up time depending on the intricacy of the design and the trace tool will trace the inside and outside of the line (even more cleanup). Keep in mind that this is with line art, black and white or colored .jpg's are better handled.
    You'll want to double check the size to make sure that the finished design matches your original.
    If the design is larger than the size of your scanner, you can break it up into sections and make several scans. You can then import each one and piece them together to make the whole design.
    CorelDraw works well for scanning in images to do the same procedure also. In there you just use "File/Aquire image/Aquire if you already have a scanner installed and selected as the source.
    If your image is repeatable, you can just trace 1/4 or 1/2 and then mirror it to make the whole.
    I suppose you could also set up some kind of scanner head to scan the image right off the ShopBot table, but I've yet to see a good/affordable setup. Maybe someone else can chime in on that.
    Feb 2004
    Rogers, Arkansas
    For scanning the edges of 2d cutouts the shopbot probe works very well. If in addition to the paper pattern you have a part made and sanded to finished shape, you can quickly scan in the perimeter using the probe.
    Ken Zey
    Rogers, AR
    www.CedarSlabSigns.com
    www.lookoutmercantile.com
    www.digitalmillwork.com
    6x12 PRS alpha
    Apr 2011
    Cincinnati
    Thanks all - I installed the software on my laptop today and will start importing some scans. Shopbot has a 4 week lead time right now - lots of time to work on the software learning curve
    Apr 2011
    Colorado Springs
    I am only 3 weeks ahead of you, still waiting. I have a lot of this stuff figured out, especially Aspire. I am antsy. I want to start cutting.
    Apr 2011
    Cincinnati
    I'm on the fence regarding Aspire - I see many projects that have used Aspire that look amazing...but it sure is not cheap.
    Delray Beach, FL
    Brian:
    Software that does what Aspire does is not "cheap" but then neither is a CNC machine! As far as value goes, there isn't a program out there that does what Aspire does that has a cost anywhere near as reasonable as well as the terriffic support. It opens up the possibilities for cash return on your investment so far beyond it's cost it isn't even worth thinking of going another route for the same results.
    Apr 2011
    Cincinnati
    After upgrading my electric service, installing a new dust collection system, purchasing a new computer, etc. etc. it's not the additional $1500 that concerns me as much as being able to utilize the capability of the software to it's fullest. The items in the software gallery sure make it look like a must have however
    Delray Beach, FL
    Brian:
    You haven't said (and I didn't ask) what your short term goals with your machine are. If it is only to cut out shapes, get your feet wet in some easy 2.5 work by using area clear strategy but having all flat top parts, a bit of limited v-carve letters, and buying any 3-d carving work from Vector art 3-d, and or doing some cabinet work then the software you get with the SB will do all that. You can always get started and buy more sophisticated software later with profits!
    You can take scroll patterns and scan them with a flatbed and import them into Partworks and then clean/trace them, recreate them by hand in Partworks, or use other software to do a trace of a scanned image. It's a bit of work but neither PW nor Aspire does that terrific anyway.
    Aspires strength is allowing you to create your own 3-d work.
  1. Scanning into Aspire
    By Simops in forum Aspire
    Last Post: 11-15-2014, 08:58 AM
  2. Laser Scanning
    By khaos in forum Archives2008
    Last Post: 04-19-2008, 06:04 AM
  3. Uses for Laser Scanning?
    By myxpykalix in forum Archives2007
    Last Post: 12-30-2007, 10:44 PM
  4. 3D SCANNING
    By oddcoach in forum Archives2007
    Last Post: 04-05-2007, 04:05 PM
  5. Scanning for me?
    By itemphoto@yahoo.com in forum Archives - 2005
    Last Post: 01-29-2005, 01:29 PM
