Recently purchased a PRS 96x48 2007-2008 model shopbot w/spindle. I was told it was a single phase 5hp. Guy had it wired direct to breaker box.
Anyway machine is up and running correctly. But can't get spindle to run. What I have is a Yaskawa v74x controller, spindle is model HSD- AT/MT 1073-140. shopbot controller is the type that looks like a computer. The only wire from the SB controller is to the spindle fan and is running it fine. No other contacts from SB controller to spindle is present. Orange cable is connected to spindle. Large black cable from vfd has 3 wires black, red and green. red and black are run to a 50 amp double pole breaker and green is run to ground.
I'm in need of some serious hand holding here. As you may can tell I can't read wiring diagrams. Pictures are better for me to understand. I feel I may be under powered, as is the reason I gave model #'s.
Shop is wired 100 Amp?.
I would like to get this going this weekend or the wife says I'm sleeping with it. She don't know but when it gets going, we'll be together, me and the SB the whole weekend.
Anthony
