Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: PRS Standard
    Jun 2004
    Fuquay Varina, NC
    Default PRS Standard
    I have a PRS Standard with this control board (see Pictures) and Vexta Motors (pictures).
    My question is can I get a new control box that will run the motors that I now have. Right now if I jog at 4.00 I lose steps. Or is there adjustment that can be made in the box?
    I’ve never been fired, but, I have been laid off when they were still hiring.
    PRS Standard 48"x96" with PC Router and Aspire 9.008, Cabinet Parts Pro
    www.cncsignshop.com
    cncsignshop@nc.rr.com
    919-802-7477
    Sep 2008
    What computer are you using? Might need to upgrade to more RAM.
    Vector Studio 22
    Jun 2004
    Fuquay Varina, NC
    I've had this problem from day one in 2007 at the time I just delt with it. I've had the machine on 3 or 4 computers, all of them with 3 gig or better ram.
    I can use the arrow at 4.00 and inside the control box I can see the lights on the drivers and they get dim when I use the key. I'm thinking the power supply is not putting out the right voltage or weak.
    Thanks for your reply
    Jimmy
    www.cncsignshop.com
    919-802-7477
    Dec 2008
    , Richmond Tx
    What voltage is the power supply set at and do you have a way to watch that voltage while jogging?
    You should be able to jog at about twice that and cut at 3 or 4 with no trouble.
    At one time I had my prs gantry that was not rolling freely. That also caused the same symtoms that you have. I dropped all of my motors away from the track and adjusted everything to roll freely. Then I put the motors back in place.
    Also the motors need to be snug against the gear rack, but not to tight. If that is to tight, it would do the same thing.
    Sounds like you have plenty of ram. Do a usb speed test and see what percent you get. You may need a different usb cable or hub if you have less than 70%
    Lastly call tech support. You should not need to upgrade anything really. Just fix what is wrong with it.
    Kenneth
    Jun 2004
    Fuquay Varina, NC
    Thanks Kenneth!!
    I checked the power line going to the fan, it read 11.29 volts, joged machine there was no change in the Volts.
    Jimmy
    www.cncsignshop.com
    919-802-7477
    Dec 2008
    , Richmond Tx
    you are looking at the wrong power supply.
    The one in the bottom of the case will be at least 48 volts. That is the power supply that I would be worried about. Some were set to around 56 volts also, depending on what model. This is the power supply that does the work of running the motors.
    The power supply in the top of the box is just a pc power supply that gives 5 and 12 volts for the board.
    Kenneth
    Jun 2004
    Fuquay Varina, NC
    Don't feel stupid!!!
    I'll call shopbot in the morning and find out how to check that one.
    Jimmy
    www.cncsignshop.com
    919-802-7477
    Dec 2008
    , Richmond Tx
    The terminals are labeled on the power supply and there are a pair of wires running from it to the board. It will have 110 volts ac input and the output is what you will be looking for. somewhere in the neighborhood of 50 volts dc. It will say the voltage close to that plug. you can check it at the board or the power supply either way.
    Kenneth
    Dec 2008
    , Richmond Tx
    should look kind of like this with the ac power comming in on the N L and ground
    Then checking from ground to V+ is what will be running to the geckos.
    Kenneth
    With SB3 closed....Have you run ProgramFiles/ShopBot/Diagnostics/SpeedTest.exe ???
    If you are getting less than 70%, are you running a 2.0 self powered USB hub? If not, kick in for the $20 and get one. It should boost your speed to 75-85%.
    You can get one just about anywhere...RadioShack, Walmart, Office Depot, Staples...etc etc.
    Just plug it into your computer & plug the bot into the hub.
  1. PRS Standard 96 x 48 x 6
    By MogulTx in forum For Sale/Wanted - ShopBot-related items only
    Last Post: 02-14-2017, 02:56 PM
  2. PRS Standard
    By dan78 in forum PRS Assembly
    Last Post: 11-22-2012, 05:00 PM
  3. My new PRS Standard 48 48
    By ATX Poly Products in forum ShopBotter Message Board
    Last Post: 08-31-2010, 12:58 PM
  4. PRS Standard Jog /Cut speeds
    By wberminio in forum Techniques for Cutting, Drilling, Machining
    Last Post: 02-15-2010, 09:33 PM
  5. Prs standard
    By david_white in forum Archives2008
    Last Post: 01-01-2008, 07:37 PM
