Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: PRS Standard
  1. #11
    Jun 2004
    Fuquay Varina, NC
    The first Speed Test I did (see picture)
    And the second test (see picture)
    Brady thanks for your reply, I am not running the 2.0 self powered USB hub, I will get one today.
    On the controler it says it's for a PRT I have a PRS, I think there may be a problem there as well.
    I'll call Shopbot today and find out.
    Jimmy
    I’ve never been fired, but, I have been laid off when they were still hiring.
    PRS Standard 48"x96" with PC Router and Aspire 9.008, Cabinet Parts Pro
    www.cncsignshop.com
    cncsignshop@nc.rr.com
    919-802-7477
  2. #12
    Jun 2004
    Fuquay Varina, NC
    I installed the Hub and this is the speed test (see picture) but, it is still doing the same thing as before.
    Jimmy
    www.cncsignshop.com
    919-802-7477
  3. #13
    Well you've got good communication now...although, that doesn't completely rule out a comm problem because other USB devices can still 'stand on' the comm to the bot if you don't install a dedicated PCI to USB card on some computers (namely Dell).
    A few more questions:
    1) What are the conditions where you lose steps? - IOW - How fast, how deep, what material, just 2D, 3D or both?
    2) What version of SB3 are you running? I would update and BE SURE to install fresh firmware with UI command.
    3) Your USB cable isn't longer than 10' is it?
    4) Using Windows Task Manager - find out what is running in the background. Use MSConfig to modify startup programs.
    5) Post your VR settings fill in sheet.
  4. #14
    Nov 2007
    Brooklyn, New York
    Hi Jimmy,
    Yesterday night while reading your post I was telling me: well I'm not the only one, seems like it is been there for long time.
    A couple of years ago (end of 2007) I was doing a research on the forum about the machine weird behavior and I find out a post from Brady talking about the 2.0 self powered USB hub and the speed test, next day I went to get one of those things, hopeful that the problem could be fix I install it and run the speed thest and get an awesome 87.7 transmition efficiency but nothing change with this, then I do another research and find out about the proper machine grounding which I did, and again NOTHING!.
    I have lived with this problem all this years (3 1/2 now) I never call shopbot to talk about this problem because I thought it was relative to the standar machine, I was so convinced about this that about two years ago I ask shopbot for an Alpha Upgrade but it was close to $5,500.00 and I can not afford that.
    I blem myself now for not reporting this problem to shopbot which has been a major headache that has been avoided.
    I have the same machine you have, same motors,same board, same drivers, SAME PROBLEM .
    German.
  5. #15
    Jun 2004
    Fuquay Varina, NC
    I think I found the problem and it was a driver. I swopped out the drivers with Y&Z
    and my problem moved to the Y. So I ordered 4 of the 203, Price $611.75. Frank from Shopbot
    said they would work all I had to do was move a jumper.
    I'll let you know as soon as I get the new drivers installed how things go.
    Jimmy
    www.cncsignshop.com
    919-802-7477
  6. #16
    Nov 2007
    Brooklyn, New York
    thanks for that Jimmy, I hope it works, for you and for me.
    Plase kepp us updated.
    Thanks again.
  7. #17
    , CALDWELL IDAHO
    With my standard, I grounded, went with a 2.0 usb powered hub on it own seperate pci card. The biggest improvement was going with a cordless usb mouse. Still can only jog at 8.75 ips. comm speed at 84.6 so I'm interested in the change of drivers as well Jimmy thanks for the post.
  8. #18
    Jun 2004
    Fuquay Varina, NC
    I just got an email from GECKODRIVE INC and they have been shipped, I’ll get them Wednesday. As soon as I get them installed I’ll post the results.
    Jimmy
    www.cncsignshop.com
    919-802-7477
  9. #19
    May 2006
    Ontario Canada
    Russ are you running a standard machine? And is it circa 2007? If you are running a standard and getting that jog speed I think you are doing well and might be close to your jog speed limits...but I am no expert. My standard is from september 2007 and I can now jog at 7 ips safely. I am curious as to what computer you are running and how the wireless mouse helped?
    Jimmy, great news do keep us posted on your results.
    Glen
  10. #20
    , CALDWELL IDAHO
    Yes, Glen sounds that we got the same machine at the same time. I have tried a couple of computers but go back to a Compaq Pasario. I believe that the cordless usb mouse tricks Window in the way that it uses the IRQ for the machine.
  1. PRS Standard 96 x 48 x 6
    By MogulTx in forum For Sale/Wanted - ShopBot-related items only
    Last Post: 02-14-2017, 02:56 PM
  2. PRS Standard
    By dan78 in forum PRS Assembly
    Last Post: 11-22-2012, 05:00 PM
  3. My new PRS Standard 48 48
    By ATX Poly Products in forum ShopBotter Message Board
    Last Post: 08-31-2010, 12:58 PM
  4. PRS Standard Jog /Cut speeds
    By wberminio in forum Techniques for Cutting, Drilling, Machining
    Last Post: 02-15-2010, 09:33 PM
  5. Prs standard
    By david_white in forum Archives2008
    Last Post: 01-01-2008, 07:37 PM
