First I have a prt alpha running control software 3.6.16
After setting my z zero with the zeroing plate I was moving the machine with keyboard input when I received a flashing input 4 error. This has happened before and I have just pressed the reset button. This time it did not work?
I searched the forum and vn switch 4 stop type was set to closed stop and input switch #3 was set to 1 open limit?
I also checked continuity on the emergency stop and it is functioning properly.
Now I have a red line on input 4 and I still can not connect to the machine?
I am concerned that there is still continuity across es3 and es4 this does not seem correct for a open stop? I am also emailing this to support@shopbot.com in the hope of being running again ASAP.
Thank you,
Dan
