We have to cut something like 100-200 of these little box things
-they're about 4 x 6 ins. in size.. out of 1.75 ins. thick Mahogany.
We're using a 0.5 in. spiral upcut bit by Amana.
I'm getting this annoying little groove happening in all six passes
(see attached pics below)
The flaw is happening on only one 6 in. side of the boxes, as the machine cuts in Y
going out from my nearby side of the table --but not on the other side, coming back in.
I've had a look at the racks/pinions,gear cogs
and even cleaned the center grooves of the wheels -the rails seem OK if a little worn.
I've cut several of these boxes across the table in several different X-positions
so I feel it's something going on in Y?
_______________________________
Could it be a Z problem?
Could it be a slightly-loose router in the frame?
One of our two hose clamps securing the variable-speed 3.5 hp Porter-Cable is ..ah... in need of replacement
but why is it happening in just this one spot, on one side only?
I've lined up a few of the boxes but, as you can see,
it's not happening in precisely the same place along that 6 inch run in Y.
What gives? Ideas?
