Have you tried reversing direction? climb/conventional ???
Kenneth
I also use Vector ... (Vector 12 now!). I agree it is a good product. It can now process Rhino files even and has quite a few features. IMSRVE continued to support their product. Just support is limited , I believe , to latest version only. If you want to send me the file I can try it on my PRT. (furnituremaker atabout live.com).
Dusty
Olympia, WA
I'll volunteer to toolpath in PartWorks, Aspire or ArtCAM Pro if you send me it as a DXF or EPS. This would eliminate it being Vector. Let me know the following:
1) Zzero on top of the material, yes?
2) Material thickness?
3) Stepdown
4) Speeds (you can modify via FE)
5) Bit diameter
Also, have you tried Scott's suggestion of cutting in a different location on the table?
That snippet of code runs smoothly on mine and I see no indication of any hiccup in the code.
You haven't answered as to whether the machine actually pauses at that spot or if it's just a bump due to a mechanical issue and does it happen somewhere else on the table as well.
The only other thing I thought of was that way back when, there used to be an issue with loops from CG's and you needed to take values out to 6 digits past the decimal point instead of the default of 4, but the divot is happening well before the corner which leads me to believe that you may have a divot in a rail.
Check to be sure one of the workers/helpers doesn't have a rubber mallet in his back pocket and that he doesn't give it a whack at just the right time when you're not looking. In the picture, the divots are close to the same, but not exactly. He needs to work on his timing just a bit.
It's getting close to going home time, here
but a few quick answers to you helpful gents...
The client expects miracles without even confirming an order, or making a down payment.
We're not about to cut much more expensive mahogany, thus we're holding back a bit on this particular project
thus my not having made any further experimental cuts at difrnt parts of the table, etc.
but this will happen soon, after corrections to Z, which may well be part of the problem!
We have some Z issues with one of the two circular clamps that hold the Porter Cable to the Z column
-those should be addressed tom. a.m. since we have two new hose clamps and carpet tape
---just waiting on the boss to get back in town and we'll fix it up hopefully
...it takes 4 or 5 hands, needs squaring up too!
As stated in previous post, I haven't been too adventurous re. cutting elsewhere/experimentally
coz this is expensive Mahogany and the client is...well.....never mind...
and like I said, there ARE Z issues to be corrected and then we'll get experimental, I'm sure.
This problem has to be physical/mechanical....rails, fluctuations in Z or in Y(rails)....
Hose clamps to hold a router in place is kind of scary all by itself. They make real mounts for those things you know.
Kenneth
Hey, this is life on a small tropical island.
This is Carlisle Bay -about 5 mins. away from my house!
Wouldn't be fun if we weren't using lo-tech stuff like Bamboo an all.
We bin using two stainless-steel hose clamps to hold the Porter Cable in place now
for ten long years.
It works... most of the time....but tell me about those Real Mounts.
A URL would be nice..
That mount is junk. It was OK for a PR back in the day that didn't go over 2 IPS and Z speeds 1 or under. The machine probably had enough slop in it to mask the flex in the mount. Get one of the cast AL ones:
http://www.shopbottools.com/files/SB...mblyBinder.pdf
Page 35 - "Mounting the Router or Spindle"
You'll have to call SB for a price.
