Eric...
Put some scrap on the table and try this: 1/4 Dn spiral, 10,5000-12K rpm .25 +/- per pass and 2 ips. That should get you some chips, reduce the scream and let your bit live a lot longer.
Eric...
Gary Campbell
GCnC Control
GCnC411(at)gmail(dot)com
Servo Controller Upgrades
— Albert Einstein
I built one of these 10+ years ago from some plans in ShopNotes magazine.
http://plansnow.com/dn3079c.html
The thing has logged a million miles and works great for sanding edges and any radius that's 2.5" and over. Uses a 6" x 89" belt.
Also picked up a MasterForce Oscillating Spindle Sander from Menards and was pleasantly surprised that it's really pretty decent for $199.
Eric,
thanks for the details - made wooden round solitaire marble games a while back and sanding the edges (cross grain would create fibers) was such a pain and time consumer that i switched to square shape. your stack of boards show no signs of heavy or uneven sanding - nice work
adding to other comments - my wide belt sander (performax 16/32) and bandsaw are probably tied for the tools i could not live without. nothing goes for engraving on the bot before it goes through the surface sander. also have a ryobi spindle sander that is great.
I bought one of the 30 inch drum sander kits from Stockroom Supply and I just love it. I used thier plans on the Bot and made my own box. The unit works terrific and the dust collection is remarkable.
http://www.stockroomsupply.ca/shop/d...c2cbaf9&cat=40
Russ
I just purchased the Delta 18/36 drum sander. Any tips? What grit do you keep/use most often in the sander?
Hey Eric! Beautiful work. Where are you buying the metal pegs from? I have a 38" Wood Master. Great machine. I use the Klingspor 80 grit for flattening and it lasts a surprisingly long time. After that my festool ROS makes quick work with the rest of the grits. It's expensive for a ROS but the dust collection is second to none.
Thanks for the compliments guys!
This is where I buy my pegs: http://www.petespegs.com/
Eric Erickson
Shopbot BT48 Buddy
I like the sales tactics. Sounds like you have a gift for selling people on an idea.
I have one of the rigid sanders as well and its a decent oscillating spindle sander. The oscillating edge/belt sander attachment is interesting but its a bit odd. I would plan to get a disc sander go to along with it as small parts tend to catch on the belt without a stop.
I have an old Powermatic 30 belt disc sander out being restored at the moment, but when I get it back I will primarily leave the ridged setup as a spindle sander.
The finish on the cribbage boards is complete and I delivered the boards to a very happy customer today.
Eric Erickson
Shopbot BT48 Buddy
Eric
First I want to tell you thank you for posting the sign process. I was making some, but greatly improved the quality and time learning from your posting.
I build a couple hundred crib boards a year. Fun project and people seem to really like them.
Like Gary pointed out, you may be running your bit to fast - I run my 1/4 down spiral 2 flute end mill bits between 10,000 and 12,000 RPM on most woods, but especially maple and oak. I cut at speeds between 2 ips to 3 ips on most projects. Once in awhile I will slow it down, but if I am worried about accuracy, I cut back on the overlap rather than speed.
Also I quit using felt feet, as the boards slide around. I started using a non-skid rubber pad by Sheppard. You can research 9974 - Sheppard Hardware to find where they are sold. I buy mine from Ron's Home and Hardware, as I can get them about half the price I can find other places. Also I have found them on Amazon.com, but not as inexpensive. I get my metal pegs from Lee Valley Tools. If I buy 100 or more at a time, the price is around 60 cents each and they are nice looking pegs. They carry brass, aluminum and black so I can do 3 player boards. I just need to find the red pegs so I can start building cutthroat boards.
I also put a keyhole in the back. I sold a couple of them to a guy working in Japan and he gave them to a Japanese couple (elderly) he stayed with. They decided they didn't want to learn crib, but wanted to hang them. So I started putting the keyhole in them. People do like them. I also carve my logo in the back and have gotten good comments about that.
Nice work.
Butch
