I'm looking for specs on the motors on an older PRT standard. The machine's motor's are all the same which was a custom option. 7.2-1 gear ratio 1amp motors. The machine also needs a new controller. Not looking for steps per inch etc, i can figure those out for the machine. What i have is a usb signal generator and software from my old cnc router. I believe this signal generator may run the motors however i need the specs on them first. The old machine uses 269oz 2.1amp steppers and the sb motors are simply marked 1amp. Just trying to get a baseline of info to see if it'll work or not. Any info is appreciated and tech support hasn't been helpful so far. voltage, ohms, oz, etc is what i need from the motor itself.
Randy
