so i planned a couple easy projects on the bot to make sure that everything is accurate and functioning well. these were done in bluefoam (2in) with centurion upcut/ballnose bits.
the first "3d" test was carving some topo maps of the mountain ranges around my warehouse. cut time was about 2 hours at 2-3ips. i am happy with the results and look forward to doing more and more of these.
the piece is 1ft by 3ft, my camera distorts things a little but it makes you feel closer to the piece.
GOPR1281 by strangesnowboarding, on Flickr
another project was my first CNC cut sign. it is also 2in foam, primed and painted. this is my first attempt at "fake" woodgrain and i think it is a promising start. sign is also 1ft by 3ft. it took around 1hr at 2-3ips.
GOPR1278 by strangesnowboarding, on Flickr
all the files were made in rhino3d, and toolpathed using MADcam. exported into gcode and then converted to shopbot code. it took a few tries but i think i have the workflow figured out!
i have also been doing some profile cutting to make random things for the warehouse. nothing worth photographs except the dust boot i made.
1/4in plexi with some cheapo vinyl from the local hardware store. simple but effective!
GOPR1284 by strangesnowboarding, on Flickr
thanks for checking it out, i hope to be doing more and more as time goes on.
