After several years of collecting various ShopBot components I finally decided to build a standalone indexer.
A couple of months ago I bought rails off the forum from a botter that was upgrading from 4' to and 8'. Getting the extruded aluminum, hardened rails and racks was the last thing I needed to start this project. I already had a 4G board, motors, indexer and a Z axis assembly.
In this design I will use one of the extruded rails as the base for the indexer. I mounted the hardened rail assemblies to opposite sides of one extruded aluminum rail.
A plate was cut that will be the bottom of the gantry carriage. Four Dual Vee wheels are mounted to this plate. Two of them are fixed and two are adjustable. That way the preloading of the wheels to the hardened vee rail can be set.
This plate also holds the stepper motor that will drive the gantry. Because this design makes reaching the motor mounting bolts difficult, a separate motor plate was cut. This way the pinion engagement can easily be adjusted.
The second extruded rail will be cut in sections that will make up the rest of the gantry. Two vertical and one horizontal cross piece. The Z axis will then bolt to top cross section.
These are some pictures of what I have done so far. Keep in mind these are views of the bottom of the gantry plate. The indexer will mount to the other side.
