Results 1 to 1 of 1
Thread: simple questions about adhesive/sealer
    Oct 2010
    Southwest Kentucky
    Default simple questions about adhesive/sealer
    I've spent hours reading everything I can on plenum/vac/tables. With all your experience, what is the best adhesive to use between my birch and the plenum and what is the best sealer and application method for the plenum? (yellow glue, poly, shellac, tight bond, etc.) Should I surface the birch plywood before attaching the plenum? And wouldn't it be more adaptable to use gasket in the cut lines instead of leaving a 1.5 inch ridge between your zones? Then you could change your zones as needed.
    God's Girl
  1. plenum sealer
    By Josh Beckmann in forum ShopBot Accessories
    Last Post: 03-11-2014, 07:56 PM
  2. Sanding sealer with dye or stain.
    By khaos in forum ShopBotter Message Board
    Last Post: 01-26-2012, 08:47 PM
  3. simple questions about adhesive/sealer
    By God's Girl in forum Variations & Modifications of ShopBots
    Last Post: 11-14-2011, 07:14 AM
  4. Simple or not so simple wooden head shape hat blocks.
    By gladhatter in forum Archives2007
    Last Post: 10-16-2007, 11:43 PM
  5. Clear sealer with latex paint?
    By jlawren6 in forum Archives2005
    Last Post: 08-23-2005, 07:58 AM
