Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
Thread: I cut my head badly on my BT48 today...
  1. #31
    Red face
    wHAT DEPTHS DID YOU SET YOUR TOOLPATHS FOR WHEN MAKING THE (****) round lithopanes? I know you said the pipes are not exacly round but did you "skin it" first or just go a little deeper with your toolpaths?
  2. #32
    Feb 2009
    Hobe Sound, FL
    Jack-
    I experimented with the necessary depth of cut gradually until I found it was just cutting all the way around. I used the cylinder gadget in Aspire.
    When I had a "true cylinder" (Skinned it), then I re-zero to the top of the cylinder, and setup a new file using the wrapping gadget, not to exceed my remaining material thickness for the lithophane.
    I measured the height of the pipe, and subtracted a few inches from each end for clearance to determine my "material size" in Aspire.
    I checked the pipes remaining thickness with a micrometer.
    I opened a new Aspire file and set the size, imported my photo, constrained it with a box around the picture, then subtracted the height of the photo.
    I needed to make sure it wasn't going to cut through, so I checked the remaining material below the file. It looked about right. .015 - .020
    I cut the rough toolpath with a 1/4" end mill.
    The finish toolpath was cut with a 1/8" ballnose.
    I used the indexer post processor for both.
  3. #33
    I have a pair of Bosch 6" extrusion 'risers' for raising the gantry/table sides up for extra clearance when using the indexer on a BT tool. This is what I did when I had the indexer on my BT48.
    Email if interested in purchasing them + hardware & plates to mount them on the tool.
    -Brady
  4. #34
    Jun 2012
    Ohio
    Good stuff here for the start of my indexer info hunting.
    Thanks, Brady!!!
  1. BT48 Rebuild
    By dewey_dog in forum ShopBot Buddy
    Last Post: 04-19-2016, 05:48 PM
  2. PRSalpha BT48 Clamping
    By jfarrow in forum ShopBotter Message Board
    Last Post: 04-11-2013, 12:14 AM
  3. BT48 to 4x8 ?
    By ghostcreek in forum ShopBot Buddy
    Last Post: 01-18-2010, 02:17 PM
  4. Thinking of a BT48
    By ajf in forum Archives2008
    Last Post: 05-13-2008, 02:49 PM
  5. Replies: 2
    Last Post: 03-15-2007, 07:26 AM
