I'm getting my first shopbot this month. I have the airdrill along with the spindle and will be cutting and punching holes in the aluminum bar. the bar is 1/2" and 5/8" thick. it will be cut to length on a bandsaw and then trimmed on the router table. there will be 5/8" holes punch through the aluminum using the airdrill, and then cleaning up/ tapering the edges with the spindle. in the 1/2" pieces i will be punching holes that will then be threaded.
my only concern is what bits to use. Im looking through the ONSRUD catalog and i dont know what i need. downcuts, upcuts, single flute, double flute... the diameters i can figure out, but the type of cutter i need to use for each of these is really what i need help with. at least a starting place, i figured i would get several to test and figure which one works best for each application i have.
does anyone have any advice?
