Based on the talk on the forum that independant axis control via software may be a while in coming, my thought that the simplest and probably cheapest alternative would be to mount a jet mini lathe inbetween the indexer and tailstock.
I see John Haggerty's setup but i'd rather have a direct connection as you can see my setup.
My questions are, has anyone set one up in line with the indexer? Do they line up properly? If not what did you do? If so what type of connection did you use to connect the shaft of the indexer to the lathe? I was thinking of using a double locking collar like on my legacy unless someone has a better solution. I would prefer some type of quick release system because i know some day i'm going to turn it on while it is still engaged to the indexer and would prefer not to screw anything up.
I have seen the jet mini's and if they are belt driven wouldn't it be easiest to just disengage the belt when in use as the indexer but still need a quick release from indexer shaft when using as lathe.
