I sent some of these questions directly to SB, but thought it would be helpful to get some opinions here as well.
We have had our PRT Alpha with extended Z-axis for quite a while, and last week we finally got around to upgrading our Z-axis and the motors. Because we have such a tall z-axis (16" or so) we always had some chatter while cutting thin, but denser material (plywood). The upgraded Z-axis seems to have made that much better, but we still have one minor remaining issue: that is some "ringing" in the y-axis.
Things appear much stiffer now, but the y-axis still moves a bit when the cutter changes directions. For example, if we are cutting a rectangle (say in plywood), it moves fine and does not chatter when moving in the Y, but when it rounds a corner and changes to the X direction, the gantry has some momentum that makes the X rails actually shake a bit. This results in a wavy cut.
My thought is that there are two ways to fix it: One would be to
adjust the ramp values so the machine slows down more significantly
before it changes direction. The second would be to somehow stiffen
the long X-axis rails so they don't move.
So for ramp values: We are just using the defaults. What kind of
numbers should we be considering to help with this issue? Typically
we are either cutting plywood or urethane foam. For a 2 fluted bit,
we keep the spindle RPM's around 10K, using moves speeds of 1.5-2
(x,y) for wood, and 4-6 for the foam (x,y).
For stiffening up the X rails: We need to keep the ends open for
loading/unloading material and access to the cutting area. So our
thought was that either adding another leg set in the center might
help, or filling in the void between the X-rails (the entire length of
them) would stiffen them up over all. I have attached a picture to
help illustrate these ideas.
Thoughts?
