Results 1 to 8 of 8
Thread: Layout problem
    Feb 2012
    Cntrl DE
    Unhappy Layout problem
    Morning everyone!
    First post on this site and have a challenge for you already.
    Problem laying out a design on an upside down sphere. (Wider at top - like a martini glass) I am trying to place a stencil on a sphere and it becomes distorted due to the shape. A straight line or design will fold upwards forming a cup shape rather than remain straight as designed.
    Any suggestions or formulas to eliminate the problem?
    Have a good day!
    Steve
    Cntrl DE
    atog254@comcast.net
    Hello Steve C
    And welcome to the forum! What software are you using? A screen shot will go a long way toward getting the right person to help!
    Steve G
    Feb 2012
    Cntrl DE
    Back at you Steve!
    Thanks for the quick response.
    Been using Corel Draw since 3.0 - currently 12.0 Don't see enough reasons to upgrade at this time.
    About to leave and will be gone all day.
    Steve C
    Steve C
    Corel 3.0 is about when I stopped using it...I still haven't got it straight in my mind if this is a 2D or a 3D issue. "Sphere" tells me 3D but I wasn't aware that Corel was a 3D design program...
    Anyone else?
    Steve G
    Nov 2009
    Elliott Design,
    Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
    Nov 2009
    Elliott Design,
    Steve,
    Creating the layout for spherical or domed objects is simple in Corel, you create the layout as normal and then use the envelope tools to distort it to the shape of your dome, or if it's a perfect sphere you can use the fish-eye lens tool to distort the shape.
    Problem is you are still cutting the stencil from a flat sheet and it's not going to conform to the dome shape no matter how it is laid out.
    Steve G., no CorelDraw is not a 3D program, you can do some 3D effects that only appear dimensional, the objects you create cannot be moved in a true 3D space.
    Larry,,,,
    Feb 2012
    Cntrl DE
    Default Solution to a spirical distortion
    Larry
    I think you understand the problem!
    In the past, I've applied a stencil onto the sphere and used a jig to draw a line by rotating the sphere & stencil. Once drawn, I then scan it and then import into my design and then distort the artwork to conform to the arch caused by applying a 2D stencil onto a 3D object.
    Not perfect, but it worked. Now, Looking for a better solution to the problem.
    Steve C
    Cntrl DE
    Aspire or ArtCAM Pro have the ability to create a dome in 3D, and then you can project 2D artwork upon it. You also have the capability to do vector distortion in both of these programs as well.
  1. Shop Layout
    By ADAPT_Shop-Brady in forum ShopBotter Message Board
    Last Post: 01-15-2016, 02:08 PM
  2. Layout & Design
    By joe in forum Sign Making
    Last Post: 02-07-2009, 09:03 PM
  3. Sbsys.log layout
    By bcammack in forum Developers
    Last Post: 12-17-2008, 10:06 AM
  4. Keyboard layout
    By ljdm in forum Archives2008
    Last Post: 01-08-2008, 07:50 PM
  5. Electrical Layout
    By Gary Campbell in forum Archives2007
    Last Post: 04-24-2007, 01:11 AM
