Results 1 to 8 of 8
Thread: incorrect setup
    Sep 2011
    New Hampshire
    Default incorrect setup
    I have a 2006 PRT Alpha. I had the current version of the SB software running fine until I switched computers. When I go under tools and use the setup shop bot it shows that my tool is a PRS Alpha. I went into the utilities to reset and reload the correct PRT defaults but when I go to set up the change is never reflected. I tried deleting and reloading the software, but it has not helped. Any help would be greatly appreciated. BTW I am running windows 7 pro if that makes a difference.
    Oct 2010
    TX
    Call Frank at SHopBot. He will have you set up in no time. Probably need to go in and delete a file--- but ask their Tech Support people ( Frank, et al)
    This should get you fixed RIGHT and FASTEST!
    MGM
    Sep 2011
    New Hampshire
    I spoke to Frank today and the issue seems to be when the values for the x and y axis are input for the alpha 7.2 motors the software automatically defaults for the PRS and if I change the prox switches for the PRT it still can't run a c3 command. I tried to load the software for a prt alpha with standard motors and the software shows a prt alpha in the setup. When I manually change the x and y values for the 7.2 motors it reverts the setup to PRS. Does anyone have a work around ? I think I will end up having to get the PRS style prox switches. Has anyone experienced anything like this?
    Sep 2009
    Surrey, UK
    You could edit the XYZero file directly so that it doesn't get the switchtype from the system variable.
    Oct 2005
    s5mfg.com, Hutchinson Minnesota
    Delete the shopbot .ini files and then restart the control software .enter your unit values for the new motors , and then run the setup routine and find the right setup for the machine . Make sure you have you x and y axis at your 0 ,0 location before you delete the ini files .check the unit values after that to make sure they are right.
    There is a way in the software to tell it if you have normally open or closed limit switches the alpha ones are normally open and the prs ones are normally closed .
    I hope this is what your looking for .
    Sep 2011
    New Hampshire
    Thank you for your replies. I tried what stephan suggested and it did not work. How do I do what Adrian suggested?
    Oct 2005
    You may also need to update the firmware
    Sep 2011
    New Hampshire
    Default fixed
    Thanks for the help. I modified the code for the routine and it is working well.
  1. Drilling holes incorrect position
    By bill_lumley in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 01-13-2012, 08:10 PM
  2. Incorrect drilling?
    By chunkstyle in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 10-01-2011, 09:00 AM
  3. Help: Incorrect Cut Size
    By diapowder2000 in forum Archives2006
    Last Post: 04-27-2006, 12:55 PM
  4. Incorrect Text Size
    By ljgomes in forum Archives 2004
    Last Post: 07-02-2004, 09:11 AM
  5. Shopbot software displaying incorrect depth
    By Mayo in forum Archives - thru 2001
    Last Post: 07-03-2001, 10:44 PM
