Results 1 to 10 of 10
Thread: Epoxy Resin
    Jan 2010
    , Cape May NJ
    Default Epoxy Resin
    Hi guys. I've been making a lot of table tops lately using a dished 3d model and then filling the relief with 2 part epoxy resin so the top is smooth and flush. Man that epoxy stuff is expensive. Does anyone have a source that may be more economical than the $80 a gallon that I'm paying now or even a new product to achieve the same effect? I have done the Google thing, but thought I'd ask here also. Any push in the right direction would be fantastic. Thanks.
    Mar 2011
    Arnold MD
    Quote Originally Posted by kurt_rose View Post
    We've had good luck at about 2/3 that price with
    http://www.epoxyusa.com/category_s/3.htm
    May 2006
    , SW PA
    Quote Originally Posted by bob_reda View Post
    Yep...Have used that stuff for years. The 2:1 kit is a great value. Do yourself a favor & get the pumps.
    If you want something that can be used outdoors, Greenlight sells some really fantastic stuff that is made to hold up in the sun.
    Jan 2010
    , Cape May NJ
    Thanks Guys! That's why this is the bestest sight out there . What a huge savings to help the bottom line.
    Norman, Ok
    Kurt,
    Have you considered using the old tried and true Weldwood Plastic Resin Glue? It's available from most lumber yards and hardware stores. Five dollars of it will go a long, long way.I've been using it for years and never had a failure. It's cheap and tough.
    This is a powder to mix with water. I recommend mixing a consistency of heavy cream. For our panels we us it thick as peanut butter.
    I'd suggest buying a couple of dollars worth, mix it up, and glue up a couple of boards. Throw them in a bucket of water and let stand for a week. I think you'll be pleased.
    com
    Joe Crumley
    www.normansignco.
    Jul 2011
    Timmins, Ontario, Canada
    Quote Originally Posted by joe View Post
    Kurt,
    com
    Joe Crumley
    www.normansignco.
    I think he is using the epoxy to make the carved surface flush, not glue up the panel.
    The cheapest way to buy epoxy is in larger quantity. I have purchased 5 gallon kit sizes (when working on a few cedar canoes or boat repair). Try sourcing from a marine supply company - I have found it cheapest, at least here in Canada, from places that cater to boat building & repair.
    AJC
    Feb 2010
    SOUTH CENTRAL COLORADO
    Default picture
    i have a gal and a half sitting on my shelf and have yet to use it. but the ideas are the same as yours, (a bowl shaped cutting) so i am definitely interested in seeing any pictures that you care to post.
    Jan 2010
    , Cape May NJ
    I'll try to post some over the weekend.
    Oct 2008
    Evergreen Wood Designs, LLC, Acton Mass 01720
    Default Raka Epoxy
    I have used RAKA epoxy out of Florida to make wooden boats
    http://www.raka.com/epoxy.html
    There are reviews out there which gives it high marks and is around 80/ 1.5 gallons
  1. Resin paints?
    By DarinB in forum Sign Making
    Last Post: 11-02-2018, 07:25 AM
  2. Machining plywood that has pockets filled with epoxy resin?
    By MJ in forum Techniques for Cutting, Drilling, Machining
    Last Post: 12-03-2014, 12:57 PM
  3. Really Strong Glue or Resin
    By cartar929 in forum Sign Making
    Last Post: 03-21-2010, 05:32 PM
  4. Gluing PolyCarbonate to Resin
    By davidp in forum ShopBotter Message Board
    Last Post: 07-04-2009, 05:25 AM
  5. MILLING PHENOLIC RESIN
    By THEMARKHOLM@HOTMAIL.COM in forum Archives2004
    Last Post: 04-09-2004, 10:54 AM
