Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: Revised dust collection foot
    Jul 2011
    Timmins, Ontario, Canada
    Default Revised dust collection foot
    I have realized quickly, that the stock shoe on the Buddy is not ideal for many applications. If I was cutting a lot of thin flat stock, it works fine. For the thicker (1.75") boards and seats, etc I have been working on, the shoe gets hung up on the clamps, the vinyl fingers go from 1/2" above the work to smushed down and almost torn off.
    This morning I remembered a thread where a fellow here made a new mount to keep the shoe at a fixed height, and it seemed like a good idea.
    Here is my take on it. A piece of aluminum angle I milled a slot into, held to the spindle mount with some 1/4" by 20 screws (the holes were already drilled and tapped).
    A piece of 3/4" by 3/4" aluminum bolted to that, and the stock shoe I slightly modified (cut off the bent tab, to better clear the spindle as it comes down to the bottom of the stroke).
    All in all, took about 1 hour to make, seems to work great.
    AJC
    Sep 2009
    Surrey, UK
    I thought the standard fixing worked at a fixed height as well?
    Or maybe the buddy is different from a "normal" PRS...
    Quote Originally Posted by adrianm View Post
    Not on a PRS. The PRT used to be able to be set at a fixed height. The stock dust foot is really well suited for sheet stock. 3D or deep carving is a no-no.
    Nov 2011
    Earth
    Something like this would be amazing for filming on my ShopBot Desktop. Right now it's like a magic box covering all the fun stuff and it's up to the imagination to figure-out what's going on - would really help with multi-camera work too! I'll have to look into making something like this for it in a few months after I settle-down.
    Jon
    Founder of CNCKing.com (Project files for your ShopBot Table Router) and CNCROi.com (Custom CNC Shop)
    Mar 2010
    Durham, NC
    Default Mod More
    I just finished replacing the set screw for the dust foot with an air cylinder. I was thinking the next mod would be just as you are showing here. Since the shaft that supports the foot moves freely when the air cylinder is disengaged I will probably leave it in place so I can have the best of both when I need it. I like the slotted adjustment as well, when not in use can just be raised up above the spindle head. Nice work.
    Architect, Designer, Shopbotter
    On mine I use eye bolts so I don't need tools to move it. Have thumb screws but find the eyes work better.
    Jul 2011
    Did you make it fixed as well? I think it works far better. It is also easier to change bits as well, bring the tool up and you have easy access to the spindle/collet nut.
    AJC
    Yes mine is fixed I posted pictures of it before on here.
    Jul 2011
    You are probably the guy then that gave me the idea! Thanks!
    AJC
    Jul 2011
    I am finding the rear mounted dust hose is causing me grief when I am using some of the clamp hold downs.
    I took a second look at the Kent cnc foot (and how the brush section comes off with magnets) and went ahead and ordered a foot and two lengths of brush.
    I think the straight up hose, mounted in front, will be more "out of the way".
    WIll report back when it arrives. For $200 (with both brushes), I feel it was worth a try..
    AJC
  1. Dust Skirt and Dust Collection
    By upsman in forum Assembly & Maintenance
    Last Post: 02-23-2016, 09:21 PM
  2. another dust foot
    By frank134 in forum Variations & Modifications of ShopBots
    Last Post: 01-23-2011, 01:32 AM
  3. Gary's Dust foot
    By bernott in forum ShopBotter Message Board
    Last Post: 04-28-2009, 08:24 PM
  4. Yet Another Dust Foot
    By Gary Campbell in forum Archives2008
    Last Post: 01-22-2008, 11:08 PM
  5. New 4" dust foot
    By bud_olsen in forum Archives2007
    Last Post: 05-17-2007, 09:05 PM
