Results 1 to 1 of 1
Thread: lost Z settings buddy 32 x24
    Apr 2010
    Revelstoke BC Canada
    Default lost Z settings buddy 32 x24
    Hi guys you have not heard from me for a while. Still making wooden toys.
    I now have a problem.
    Cutting some toy parts in a ¾ board, the job was almost done when the board moved and the bit jammed and broke. I hit the space bar sent the spindle home. Installed a new bit and a new ½ inch board this time to cut some circles zero with z plate set to top of material.
    Every thing the same as always Every thing works fine except every thing is cut about ¼ inch above the board I tried a 3/4 inch board it did the same thing cutting all above the board. I checked the setscrews in the Z stepper motor and was tight. I reset the ini files
    Set zero from table mz, 4 and it raised to 5” measured ok. Did the UR thing and checked VU and compared it with the computer in the office found to be the same.
    Just wondering if one of you experts could help me fix this problem.
    Thanks in advance.
    Klaas
    I got it fixed working great.
    Thanks guys you are the best.
    Klaas
  1. Machine Lost X, Y and Z settings Overnight
    By Walt_S in forum ShopBot Desktop
    Last Post: 01-11-2017, 06:45 AM
  2. setting up new PC on the bot, need some settings help!
    By Brett1970 in forum ShopBotter Message Board
    Last Post: 06-19-2015, 10:34 AM
  3. value settings for bt 32 standard
    By msantos in forum ShopBotter Message Board
    Last Post: 09-05-2012, 04:46 AM
  4. I can use the best settings for 2" hdu
    By knight_toolworks in forum ShopBotter Message Board
    Last Post: 05-04-2012, 04:00 PM
  5. Need help with settings
    By pro70z28 in forum Archives2006
    Last Post: 05-25-2006, 04:00 PM
