Results 1 to 10 of 11
Thread: Spindle Issues.... or not???
Hybrid View
    Sep 2008
    Southern Maine
    Default Spindle Issues.... or not???
    Hello. I went through all 256 posts in troubleshooting to see is anybody had a similar issues that maybe I am having. I had a fellow Shopbotter over today whom is much more familiar with Shopbot then I am. He seemed to think my spindle may be in need of new bearings. He said on other spindles there so quiet that you cant hear it run. My spindle is quite compared to a porter cable, when it running its a loud hummmm. It has always sounded that way. My spindle has very low hours as after 3/4 years now we are just learning how to use the router. Also, when we spin it by hand, if you put your ear up to where the fan is you can hear it a bit. Is this normal? How do I know if there is an issue? If there is, does anybody know a price range to have this fixed... Im not sure where to start here as im not sure there is really anything wrong in the first place!?!?!?
    Thanks in advance!
    Devin,
    Don't fret. Louder than somebody else's spindle is completely fine. Screaming whine or sounds that would leave an average non-CNC person to be cautioned are not. When I replaced the bearings on my spindle, they were louder than before I took it apart! Not a huge difference, but louder with new bearings. Even 'Factory rebuilt' spindles are louder than fresh new ones.
    If it doesn't sound 'all wrong' and you can't detect any slop in the shaft that would indicate slop in the ball bearings and races - then run it until it blows up. I probably had about 400,000 parts on mine before I rebuilt it...and it turned out that I probably only needed to change out the top bearing (the cheap one) in order to quiet it down. At no time was I able to read runout greater than the .0002" the manufacturer specs.
    Knowing what I know now - and how much the bearings cost, and how long & tedious rebuilding one properly can be, I'll just buy another new one when this one kicks the bucket. It's cheaper and easier to just buy the bare spindle.
    Sep 2008
    Southern Maine
    Awesome Brady... words to live by! Thank you very much for your advise! Much appreciated.
    I can echo all that Brady has said. Mine (4hp HSD) has always been a bit louder than some others I've heard and I was concerned when I first powered it up, but it has been happily cutting along for 5 years so far. Granted, I don't push it through ply all day long, but it has run for days at a time all day and all night. Run 'er till she drops.
    Sep 2008
    Southern Maine
    great. thanks scott!
    Oct 2000
    Atlanta GA
    Mine (2.2HP HSD Spindle) got noticeably louder when I accidentally [this part deleted due to extreme embarrassment over what I accidentally did - but it involved a large, expensive bit spinning really fast and hitting something that was never meant to be cut]. The sound still bothers me (not to mention reminds me of my own stupidity) every time I start the spindle. It's gotten to the point that I have purchased a replacement spindle and am ready to swap them out, but no sense retiring an expensive piece of equipment that is still working. In spite of the noise and my embarrassment I cannot detect any play using the "wiggle the nose to check for movement' technique, and I can't detect any loss of cut quality, so as Brady says I will keep on cutting until it gives up completely. These things seem to be built like small tanks.
    David Buchsbaum
    Beacon Custom Woodwork, Inc.
    dba Atlanta Closet & Storage Solutions
    404-309-9146
    david@atlantacloset.com
    atlantacloset.com
    beaconcustomwoodwork.com
  1. keyboard issues with moving spindle
    By milton in forum Test Area
    Last Post: 05-23-2016, 06:44 PM
  2. Z issues
    By Stagecraft in forum Troubleshooting
    Last Post: 10-04-2011, 10:59 AM
  3. No/Losing Comm & Spindle controller issues
    By dubliner in forum ShopBotter Message Board
    Last Post: 08-09-2011, 12:13 PM
  4. PRT - jog issues
    By Beginner guy (Unregistered Guest) in forum Archives2005
    Last Post: 09-21-2005, 03:06 PM
  5. Need Help with 2 Issues:
    By bjwat@comcast.net in forum Archives2003
    Last Post: 01-28-2003, 09:41 AM
