By all means use the 240 volt motors if you can. The amperage required for the same performance from a 120v motor is roughly double that of their higher voltage counterparts. If you ever want to run more than two motors, 120 volts would be impractical.
I am using two of the LH 6765-13 120 volt motors due to circumstance. I don't own the building I am in, and I have already had enough electrical work done, so I ended up going that route. I also had two 20 unused 20 amp circuits available. I have only run them for about 6-7 hours now, so I haven't had a chance to test how they hold up long term in my enclosure. The seem to be working just fine for the time being.
They certainly pull upwards of 10.0-10.5" HG with all my table zones closed, and I get a max of about 9.25 HG when cutting. This is at about 900' above sea level. That kind of performance for about half the cost of a FIEN is crazy. I have held parts as small as 4"x4", and when cutting through a couple of larger parts in a sheet, the vacuum doesn't even drop.
I planned on using a muffler, but I didn't want to restrict airflow any further. Keep in mind the exhaust will be hot, and the intake for the cooling fan will need a plentiful supply of fresh, cool, air. These are vacuum cleaner motors, on steroids. They make my Fesool CT33 seem like a toy.
